Walshie Posted June 5, 2025 Posted June 5, 2025 Hi all, I am doing a major refurb and had planned to use wet underfloor heating to the new build kitchen / sitting / dining area. I've factored in floor height to accommodate this. On reflection, I think it would be great to extend the underfloor to the adjacent utility, bathroom and hall areas. The problem is that this area is existing and is a timber board floor. I'm reluctant to have to make major alterations to the floor height in this area - but it would be great to avoid using radiators. I understand there are mesh type / thin profile electric underfloor systems - which would minimise the extra work and hassle. My questions are: Is electric underfloor reasonably economical to run (we'll have solar and battery etc) These areas will need background warmth only. Are the mesh / thin profile systems an option for this type of application? Is the existing floor board floor a problem - what would I need to do to this to make the approach effective? I'd really appreciate some help with this - really outside my comfort zone. Thanks, Sean
JohnMo Posted June 5, 2025 Posted June 5, 2025 16 minutes ago, Walshie said: Is electric underfloor reasonably economical to run Not really, generally 4x as much as wet UFH. Have you looked at skirting board heating. Replaced existing skirting with water heating ones. Do a Google search.
Walshie Posted June 5, 2025 Author Posted June 5, 2025 Hi, Thanks for the suggestion but as the areas are a series of small-ish spaces I might not get the heat output that will be needed? Appreciate that I don't need the utility room etc to be roasting but think a series of short runs might not be terribly effective? Thx W
