hauntedicecreamvan Posted May 1, 2025 Posted May 1, 2025 (edited) I'm planning on fitting a fully glazed aluminium door in my porch to let more light in the hall. I want the door to be glazed full height but can't decide between a single large glass panel or two panes with a midrail separating them. Adding the midrail adds a significant cost to the price of the door, but I'm not sure if there are any real benefits. I don't need to fit a letterbox slot. The fully glazed I assume wins on thermal and acoustic performance, having just a single pane. I assume that the midrail would improve the integrity of the door, but given that it's aluminium, how much does that matter? There's also the argument that if the bottom pane gets broken, there's half as much glass to replace, but then would I be able to get the same glass to match the top pane anyway? The midrail seems to win on security too, because if you smashed the full pane, you could push it out and step through, whereas the midrail glazed door would require crawling through broken glass. Any thoughts welcome. Edited May 1, 2025 by hauntedicecreamvan
Big Jimbo Posted May 1, 2025 Posted May 1, 2025 Full height glazed, with laminated glass. You wont break it. A midrail will make it look like a back door. 1
hauntedicecreamvan Posted January 27 Author Posted January 27 (edited) Thank you, this is what I went with in the end. Looks fantastic in the slim profile aluminium frame. Edited January 27 by hauntedicecreamvan
