junglejim Posted April 5, 2025 Posted April 5, 2025 I’m running into difficulty framing the corner between barge board and fascia. Here’s an old photo (we’re a lot further on now) but I think it illustrates what I think may be a problem. Rather than birds mouth with the bottom of the rafter extending beyond and below the wall the rafter is cut flat to the wall plate which leaves no overhang of the wall. If planned on fixing the soffit to the bottom of the rafter bit it leaves little overlap between the top of the wall and soffit. I didn’t think it was a problem but I think makes it more difficult to create a box corner. For example the barge board on the verge ideally needs to come down lower than the fascia. When I’m on site next I’ll takes some photos of where I’m at but wondering if anyone has any thoughts? Thanks
Nickfromwales Posted April 5, 2025 Posted April 5, 2025 We had the same problem on one job, so we just extended them to suit.
