mistake_not Posted March 21 Posted March 21 Been searching and thinking and can't think of / find / work out how do air tightness well for my extension other than taping everything in sight like @plockhart is. The extension is going to be a warm flat roof attached to an existing cavity wall, with a new full fill cavity wall. Airtightness on new walls achieved with parge coat and old walls with wet plaster. Roof buildup so far is: - plasterboard - joists - OSB - VCL - Insulation - EPDM Can see how I can easily join the VCL to either wall, and therefore am I better just omitting it, and ensuring the OSB is vigorously taped to all joists / itself / the walls, or doing something different? I don't like the idea of the VCL below the OSB, as the OSB is then effectively sandwiched between 2 airtight layers and has a moisture risk. Grateful for wisdom / pointing me to the answer elsewhere.
lookseehear Posted March 30 Posted March 30 If you search for a 'Tony tray' you'll see that a lot of people have wrapped the ends of the joists in 600mm+ DPC, which can be taped to OSB and into the parge coat on the walls. 1
Nickfromwales Posted March 31 Posted March 31 On 21/03/2025 at 16:28, mistake_not said: Been searching and thinking and can't think of / find / work out how do air tightness well for my extension other than taping everything in sight like @plockhart is. The extension is going to be a warm flat roof attached to an existing cavity wall, with a new full fill cavity wall. Airtightness on new walls achieved with parge coat and old walls with wet plaster. Roof buildup so far is: - plasterboard - joists - OSB - VCL - Insulation - EPDM Can see how I can easily join the VCL to either wall, and therefore am I better just omitting it, and ensuring the OSB is vigorously taped to all joists / itself / the walls, or doing something different? I don't like the idea of the VCL below the OSB, as the OSB is then effectively sandwiched between 2 airtight layers and has a moisture risk. Grateful for wisdom / pointing me to the answer elsewhere. Is the rest of the dwelling airtight? If not, just manage draughts and you’ll be fine without? If airtight, have you MVHR?
mistake_not Posted March 31 Author Posted March 31 13 hours ago, Nickfromwales said: Is the rest of the dwelling airtight? If not, just manage draughts and you’ll be fine without? If airtight, have you MVHR? Not yet- but working on it as part of renovation/ extension. Aim to be when I'm done. Mvhr going in as part of the same work. 1
