hendo141 Posted January 29, 2025 Posted January 29, 2025 Hi folks, Looking for a bit if advice/feedback from people who have / have fitted overlay board systems? We are doing a diy flat conversion and while everything is bare for the renovation we had considered the idea of UFH instead of rads. We have joist suspended floors so a screed is off the agenda as we suspect it would involve too much work supporting the added weight etc... Questions re: overlay board are 1. How do they feel underfoot? We plan to use LVT on top of them and one thing i had considered was if they would feel squidgey or have a bounce? 2. Do they perform well in heating up? Seems to be mixed bag of opinions online about whether they perform as well as a screed. 3. Any advice or things to consider / wish you had considered when choosing the system. Thanks in advance for your replies
JohnMo Posted January 29, 2025 Posted January 29, 2025 UFH needs plenty of insulation to be efficient, otherwise you heat the flat under you - they will like it - you won't like the energy bills! Or you will heat the worms under your flat if on ground level. Really wouldn't bother.
hendo141 Posted January 29, 2025 Author Posted January 29, 2025 35 minutes ago, JohnMo said: UFH needs plenty of insulation to be efficient, otherwise you heat the flat under you - they will like it - you won't like the energy bills! Or you will heat the worms under your flat if on ground level. Really wouldn't bother. As part of the planning BC want underfloor insulation. We also plan to convert basement level to livable space in the not too distant future. Do you rekon its not possible to effectively insulate between the joists at all?
