Hi all,
I'm currently looking at getting a heat pump installed.
I've had a quote from British Gas for a heat pump, and wondering if anyone had any experience with the quality of their install and how close they've gotten to their estimated SCOPs? They're quote is £9k (after grant) including changing all radiators.
I've also had a quote from a reputable heat geek (although not through HG directly). Their quote is £2k more (£11k) for the same heat pump and but only changing 8 radiators.
Its a significant price difference, and BG also offer 2 years 0% finance which is an added bonus, along with the first year being charged 14p per kwh for all heat pump usage, assuming I move to them.
Additionally, the BG quote is for a Gledhill cylinder whereas the HG quote is for a Vaillant cylinder (both 250l). Anyone know which is better? I'm sure I can get BG to get me the Vaillant cylinder.
Thanks in advance!
Edited by km94
Added detail
  • km94 changed the title to Installer and Cylinder decision - BG or Heat Geek?
BG will probably subcontract the job so it's anyones guess who will do it at what standard. Press them to tell you.
Gledhill are reportedly not testing their cyls 100% and leaks and rattling internals have been mentioned somewhere.
What size? FWIW I got a Vaillant 12kW HP, 270 l thermal store and 8 new rads for well under your BG quote.
Its a 7kw Vaillant. Where abouts are you based and out of curiosity, how much was your quote?
S Devon. I think your quotes are pretty high for 7kW, unless London/SE.
Try asking the HG if they can match the BG one or come near it.
I'm north west London, and got a few other quotes and all others were around the same ballpark number, so not sure I can get it any cheaper
IME they all pad the quotes with an unquantifiable amount for "MCS compliance costs" or some such which means some scope to haggle.
Tell them you would like to give them the work, what can they do for you? "Nothing for the dumb" as my mother used to say.
Various horror stories about BG on Vaillant forum, I would steer clear of them.
Edited by sharpener
4 minutes ago, sharpener said:
IME they all pad the quotes with an unquantifiable amount for "MCS compliance costs" or some such.
Yeah I was planning on doing that once I've decided which installer to go for, and then try and negotiate it down
