SBMS Posted January 12 Posted January 12 We had two sets of raynaers aluminium sliding doors in our current self build. Moving onto our second, there’s one thing that always bothered me about the way they were installed, and I want to avoid it if I can on our next. It’s a double track and The fitter drilled drainage holes in the base of the track where the rubber gasket bit is, which go through to weep holes on the outside. The internal track does indeed sometimes get water collecting and it must drain out of these holes. however I also see them as a terrible way to leak airtightness… is this a peculiarity of this door design? Do all aluminium doors have to have the same principle of drainage holes from inside to out therefore an unavoidable airtightness breach? Photo to follow
RobLe Posted January 12 Posted January 12 I think there should be an air gap all the way around the double glazing seal(the one built into the sealed units) and that air gap should vent outside at the lowest point. It’s both to vent liquid water that gets in, and to ensure that you don’t get condensation on the dg seal that will eventually make the dg unit fail. It’s true for all dg windows as far as I know.
SBMS Posted January 12 Author Posted January 12 1 minute ago, RobLe said: I think there should be an air gap all the way around the double glazing seal(the one built into the sealed units) and that air gap should vent outside at the lowest point. It’s both to vent liquid water that gets in, and to ensure that you don’t get condensation on the dg seal that will eventually make the dg unit fail. It’s true for all dg windows as far as I know. I’ll be honest, I’m not sure I understand what you mean there! Are you saying the drain holes are unnecessary?
RobLe Posted January 12 Posted January 12 I think at least one drain hole is needed to vent to outdoor air that is usually lower absolute humidity than indoor air.
SBMS Posted January 12 Author Posted January 12 4 minutes ago, RobLe said: I think at least one drain hole is needed to vent to outdoor air that is usually lower absolute humidity than indoor air. I wonder if this is the same with ‘passivhaus’ certified sliding doors as it seems an airtightness compromise.
