runcyclexcski Posted January 2, 2025 Posted January 2, 2025 Could anyone recommend a generic non-shedding non-woven polyester fabric that I could use in place of my stock MVHR in/out filters? I am not sure what rating that fabric is... it can't be better than F7, it looks quite coarse. By eye, the fabric in my MVHR is about 3 mm thick, it's 20x30 cm and it has plastic-reinforced edges for slight reinforcement). I think if I get a slightly thicker 5mm fabric, I can just shove it and take it out and trash it once a month (my local air is quite bad in the winter). I tried a fabric from an Amazon (not total rubbish, claimed to be German-made, about 10 quid per sq mt). But it was shedding fibers, I was not impressed.
JohnMo Posted January 2, 2025 Posted January 2, 2025 Are you sure you are on the correct scale. G3 or G4 sounds more like what you are talking about, not "F", I got mine (G3) from RS Components. Stock number 8279510 Filter media roll white 1mx 2m x 10mm G3. It cost about 3x what you paid and I would order again. 1
runcyclexcski Posted January 3, 2025 Author Posted January 3, 2025 (edited) Thank you, John. I buy from RS all the time, I trust them, so I should be able to source your fabric. I do not mind paying 50 quid for 2x1m pad; it's still "cheap" overall. I honestly do not know what the official rating of my "stock" MVHR filter is -- I am still waitiing for Boulder the manufacturer to respond. If G3/G4 works for your MVHR, chances are it will work for mine. Of note: I am perplexed what the difference is between these two fabrics; one is a 2 meters by 1 meter pad, the other one is a 20 meters by 1 meter roll. Similar cost, but once gets 10x more of the latter. https://uk.rs-online.com/web/p/hvac-air-filters/8279510 https://uk.rs-online.com/web/p/hvac-air-filters/1221771 Edited January 3, 2025 by runcyclexcski
JohnMo Posted January 3, 2025 Posted January 3, 2025 18 minutes ago, runcyclexcski said: Similar cost, but once gets 10x more of the latter. Bit of a p*ss take on pricing, but the big one would last you about 50 years. 1
