I have an old MYSON Velaire 110/135 oil fired boiler with a CL6 PO117 thermostat which has failed. The only supplier I could find on the internet says they are no longer available and there is no alternative.
The thermostat adjustable knob on the front panel, see photograph, sets the water temperature. When the water reaches the temperature setting the thermostat opens a pair of 240 volt electrical contacts and the boiler switches off. A very basic form of control really.
Does anyone know of a thermostat that I could use as a replacement?
Thanks for reading.
