Hi all,
I have just had a shell only extension done. The subfloor is down upstairs but joists can be accessed from underneath. The ground floor is a suspended timber floor which is just joists at the moment with a large void/crawl space underneath.
I will be putting up the stud walls on the first floor shortly and I know that now is the time to get the plumber and electrician in. Is there any particular order you guys recommend? I know plastering is done at the end after 1st fix but surely the wall that the boiler is mounted on will need to be plastered first before boiler installed and pipework run.
You can get the plumber and plaster in any order
But most will get the plumber first
Easier to run wires around pipes than the other way round
Your plumber will put the pipe work in for the boiler and put the boiler in with the Rads bath etc on a second fix after plastering and paint
