sonicboom Posted December 15, 2024 Share Posted December 15, 2024 (edited) I was going through this list: https://database.passivehouse.com/en/components/list/ventilation_small Does anyone know what the reference temp is for the heat recovery percentage ? Edited December 15, 2024 by sonicboom Link to comment Share on other sites More sharing options...
Mike Posted December 15, 2024 Share Posted December 15, 2024 It's in the certification criteria - https://database.passivehouse.com/en/components/#certification-methods-info The effective dry heat recovery efficiency [is measured with] with balanced mass flows at external temperatures of between – 15 and + 10°C and dry extract air (ca. 20 °C) Presumably the worst reading is taken. However Heat Recovery Efficiency, as the name suggests, only measures heat recovered. On that basis a unit with expensive-to-run fans can look better than one with highly efficient ones. The Efficiency Ratio is the key figure that allows you to compare units like-for-like, taking into account the electricity used as well as the heat recovered. 1 Link to comment Share on other sites More sharing options...
