Post and beam Posted November 15, 2024 Posted November 15, 2024 Hi Guys Friday question. The DPC that we need to lap to the 1200 floor membrane is really quite stiff. I am struggling to understand the practical issues of holding this down against the kicker blocks, lapping the floor membrane up over it and then stacking the kingspan 'upstand' insulation against it prior to putting the 150mm floor insulation down. Is there a tape or glue that is good enough to hold this thick DPC against the kicker blocks please that is known to be effective? Thanks in advance keith
nod Posted November 15, 2024 Posted November 15, 2024 The dpc that is lapped out of your walls needs to be dry and clean You will have to go round with a sponge and hot water a clean it all I used woven render tape or to stick ours (Jaffa)
Post and beam Posted November 16, 2024 Author Posted November 16, 2024 On 15/11/2024 at 16:37, nod said: I used woven render tape Do you have a brand recommendation? Regards keith
