keith-276 Posted October 20, 2024 Posted October 20, 2024 After almost 8 years, our kitchen units are still in great condition, other than a couple of areas that needed some attention. We have two cupboards above the hob at each side. They get plenty of steam from cooking and the edge of the white coating was starting to bubble...
keith-276 Posted October 20, 2024 Author Posted October 20, 2024 I've only photographed one side here, but the same work has been done to the cupboard on the other side as well. I used a Dremel to remove the affected material, then filled it with car body filler.
keith-276 Posted October 20, 2024 Author Posted October 20, 2024 I purchased some anodised aluminium unequal L profile (15mm x 10mm) that fitted nicely along the bottom edge of the cupboards.
keith-276 Posted October 20, 2024 Author Posted October 20, 2024 (edited) After cutting the aluminium profile to fit, I primed and spray painted them with Tamiya gloss white, giving them plenty of coats. The paint finish turned out really nice. I then used epoxy resin glue to attach them to the cupboard. The glue also seals all along the bottom edge so no more steam or moisture will get to it. Here is the end result. Edited October 20, 2024 by keith-276 1
nod Posted October 20, 2024 Posted October 20, 2024 You could add a end panel and fix it over the damage
