ChrisInKent Posted September 20, 2024 Posted September 20, 2024 (edited) I’m after some advice please. We’re just going up from the ground beam and have one course below the first damp barrier which the beam&block sits on. The gap alongside of the house will get backfilled with our clay soil. The ground worker is suggesting crushed stone up to this first block course and that we should paint it first with Black Jack. There’s a void inside so in theory the block can breathe under the house and the BJack will stop the outside edge getting as wet. Is this a good idea? Edited September 20, 2024 by ChrisInKent
ChrisInKent Posted October 3, 2024 Author Posted October 3, 2024 I’m not sure if I posted it in the wrong BH category, or maybe no one knows the answer? I did do a BH search but there wasn’t a consensus on options: do nothing paint above damp bitumen above damp render above damp brick slip above damp We now also have stainless steel anchor straps in place, so we could hammerite them or just leave block and straps exposed. If anyone has experienced this situation please do share what you did.
Mike Posted October 3, 2024 Posted October 3, 2024 On 20/09/2024 at 16:54, ChrisInKent said: There’s a void inside so in theory the block can breathe under the house The void should be ventilated with proper air vents anyway... On 20/09/2024 at 16:54, ChrisInKent said: the BJack will stop the outside edge getting as wet It shouldn't matter. Leave it alone.
ChrisInKent Posted October 3, 2024 Author Posted October 3, 2024 5 minutes ago, Mike said: The void should be ventilated with proper air vents anyway... It shouldn't matter. Leave it alone. The air vents are in now. We’ll leave it alone, thanks for the advice, appreciate it.
