HEB1 Posted September 14, 2024 Share Posted September 14, 2024 (edited) After horizontal rain blown at 50mph into our newly sealed windows - we've got water pouring in through every fixing strap. I had assumed the windows would be set into the reveals until local regs up here in Scotland dictated that 50mm of the frame would hang outside the cavity as we are cladding with cement board. How on earth can I insulate/waterproof around all those fixing straps - (Door fitted by well respected local window company) I have TP600 tape on the outer edge of the window to timber batten, Soudal SWS foam from the inside then Everbuild 625 Silicone around the edge but only a couple of mm gap between the window strap and the reveal. This is where water is pouring in and I seek advice on what to seal the gap with please. Edited September 14, 2024 by HEB1 Wrong picture format Link to comment Share on other sites More sharing options...
MikeSharp01 Posted September 14, 2024 Share Posted September 14, 2024 Going to be tough until you get the cladding on and can seal the frames to that. I would just run bead of silicone round them all until then. Link to comment Share on other sites More sharing options...
G and J Posted September 14, 2024 Share Posted September 14, 2024 3 hours ago, HEB1 said: 50mm of the frame would hang outside the cavity as we are cladding with cement board. Is that to create an unbroken layer of cement board and window? Link to comment Share on other sites More sharing options...
HEB1 Posted September 16, 2024 Author Share Posted September 16, 2024 I think more to do with Firestops surrounding the window but certainly easier to clad we hope! Link to comment Share on other sites More sharing options...
