Using zinc yellow passivated torx screws on a shed build cladding
I'm considering using the above as supplied by toolstation to fasten 19mm thick larch waney boards.
This is external use but the heads will not be exposed to the elements, the specification claims "Corrosion-resistant – salt spray-tested to 400 hours"
I prefer using torx drive as they don't cam out and are reliable.
Is this a good choice?
If using larch use stainless fixing. We have larch cladding on house all stainless not a black streak anywhere, our garage was done by others, and they insisted galvanized fixing would be no issue, black streaks everywhere.
Don't compromise you will regret it.
 I will go with stainless steel screws then
I didn't realise that larch reacts to certain metals, thank you for that
Edited by Siadwell
spelling!
