I’ve lapped breather membrane over the ridge and will be fitting dry fix vented ridge tiles. I’m hearing mixed opinions about whether I soups cut the felt at the ridge or not.
 The roof is osb Cassette with 50mm vent gap between insulation and osb… any suggestions? Layers above osb are: membrane, counter batten, tile battens, tiles
 Advice greatly appreciated 👍
