agamemnon Posted August 19 Share Posted August 19 Hello, I have received two quotes for 8 windows and six panes of glasses changed. The first quote is for £5000, and the quote mentions To supply and fit WER ‘A’ rated REHAU 70mm replacement white p.v.c.u. windows to match styles as discussed. the second quote is for £4470 and in the quote the only thing about the specifications mentioned is: All our windows and doors meet current building regulations (Low 'e' glass 28mm double glazed units - with toughened glass where required) Are there any particular questions I should ask? Link to comment Share on other sites More sharing options...
JohnMo Posted August 19 Share Posted August 19 Uw value. That is the whole window U value as opposed to UG which is just the glass. How are they installing them. You really want them foamed in with airtight expanding foam. This will give a good degree of airtightness and eliminate the thermal bridge around the frame. Many will install in the hole and then cover everything leaving a void and you get mould around the window. 1 Link to comment Share on other sites More sharing options...
