Hello,
I have received two quotes for 8 windows and six panes of glasses changed.
The first quote is for £5000, and the quote mentions
To supply and fit WER ‘A’ rated REHAU 70mm replacement white p.v.c.u.
windows to match styles as discussed.
the second quote is for £4470 and in the quote the only thing about the specifications mentioned is:
All our windows and doors meet current building
regulations (Low 'e' glass 28mm double glazed units - with
toughened glass where required)
Are there any particular questions I should ask?
Uw value. That is the whole window U value as opposed to UG which is just the glass.
How are they installing them. You really want them foamed in with airtight expanding foam. This will give a good degree of airtightness and eliminate the thermal bridge around the frame. Many will install in the hole and then cover everything leaving a void and you get mould around the window.
