Rcs Posted August 16, 2024 Posted August 16, 2024 We live in a terrace property with shared access alley and need to dig a trench for the waste pipe for a new downstairs toilet. Our neighbour is saying that he will not let us do this due to previous issue when the gas and electric have dug up the alley to replace the supply to both properties. The works we plan will not be near the utility supplies as the trench will be going to the rear of the property can he stop us from doing the work, if so what can we do legally to be allowed to do the work as there is no alternative route the pipes can take due to underfloor clearance being restricted?
Conor Posted August 16, 2024 Posted August 16, 2024 Depends on who owns the alley. You'll need to dog through the deeds and registry.
Redbeard Posted August 16, 2024 Posted August 16, 2024 Agree with Conor, but I'd also look at the Party Wall Act to see if that is relevant here. I vaguely remember reference to 'party structures' and wonder if that could be relevant to an alley. Although it is the nearest 'outside' you may not have an automatic right to go via the alley. Though v likely less convenient, how feasible would it be to dig a trench under the floor to get out to the rear (or front, if that's where the manhole is)?
TommoUK Posted August 16, 2024 Posted August 16, 2024 (edited) if the alley is shared and there are existing shared services in the alley you likely have rights to connect, maintain, reinstate, renew etc. As Conor said check your deeds (if you have them) or order a copy of the 'title plan' and 'title register' from the Land Registry. Sometime the Land Registry also hold copies of the original deeds which can be ordered. Edited August 16, 2024 by TommoUK typo
twice round the block Posted August 16, 2024 Posted August 16, 2024 If it's terraced, does it have wooden floors downstairs? They quite often do and the floor joists are normally set up on brick piers with a large void below. Another option could be a Saniflo system.
