Solaredge + storedge + LG resu prime KNX integration via modbus
VinsJack
Dear all, i hope someone could help me with my issue.
I have the following system:
1x SE6000H inverter
1x Storedge connection unit
2x LG Resu 10h prime
1x KNX modbus TCP weinzierl Gateway 716
Actually i can potentially acquire all registers from
40001 to 41275 however i know the description of few of them (the one listed on the attached document)
Main issue is how to get all info about batteries (i have no idea baout which registers are required
The second is about the KNX configuration... actually i can read values only immediately after modbus request, but i'm not able to perform any operation or function on those data... after a query, the value is always unavailable/zero... any idea about it?
sunspec-implementation-technical-note (4).pdf
The second problem seems to be solved... a security function was blocking the reading of any value if the query was coming from a device not sharing the same protocol... once deactivated the security protocol everything started to work... now oly some parameters are missing...
PLEASE HEEEEELP!
