G and J Posted August 3, 2024 Share Posted August 3, 2024 I’m either zoning in on the final details of our wall build up…… or…… I’m spiralling inwards until I disappear up my own rear end…. only time will tell (often at the moment it feels like the latter!). I do know that we will be having a layer of PIR on the inside of our frame, covered by a VCL, then a service void then plasterboard or habito or fermacell. But I don’t need a service void everywhere, in fact I’ve whole walls without a socket or switch, which leads to my question: Can I, and if I can, is it a good idea, to put up the plasterboard without battens? i.e. straight onto the top of the PIR? I presume not, but my assumptions may seem logical to me but keep being proven to be completely bogus. If so I can use more PIR, which is the motivation. Link to comment Share on other sites More sharing options...
Mr Punter Posted August 3, 2024 Share Posted August 3, 2024 There is no issue with plasterboard onto the PIR. You will need longer PB screws. It is pretty much what you get with thermal laminate board. I prefer them separately as it means it is possible to separate them at end of their life. Please don't use Fermacell. Massive ball-ache. Link to comment Share on other sites More sharing options...
