Andeh Posted July 21, 2024 Posted July 21, 2024 I have a central network hub, cat6a all over the place. hard wired internally is mostly complete. The next phase I am planning is some external POE cameras. I am looking at Annke as cost v capability. We have 2 x CAT6a poking out the wall sin various areas. Cables are expanding foamed in for Air Tightness, then rendered as well. In terms of the physical install of the cable, what should I expect in terms of manually wall mounting them & plugging in the cable? I generally use keystone CAT6a jacks, for ease f installation but these are quite bulky. How do you hide the cable & jacks behind the camera? Thanks,
Alan Ambrose Posted July 21, 2024 Posted July 21, 2024 Maybe put in a small IP box, carefully spray paint that and the camera to match your eaves or whatever.
