Hi.
My architect positioned the water and electric coming into the plant room under the MVHR unit, which my groundsman has done as per the plan. Does anyone know how high a stop top needs to be or how much space do we need to leave below the MVHR unit? I don’t have a plumber on site yet to ask this and MVHR needs to know / tell MBC so they can agree the joists.
i am assuming the electrician just go around the edge of the room so it an issue?
many thanks
Sounds like a plant room so I would board the wall out so fixings can go anywhere, stop tap best near the floor i guess then plumber has more flexibility.
So the stop tap doesn’t need to be a minimum height off the floor? Is 12” enough clearance?
thanks
