Silly Question?
I have an Impey tray fitted, which is flush with the floor.   Floor to be  covered with waterguard membrane. Electric UFH on top of this, which will also be over the shower tray.
Intended to have a thin coat of self leveler on the UFH cables to make tiling the floor easier, but what happens over the shower tray? If I put self leveler on the tray it will loose the fall to the outlet.
Am I missing something.
Cheers.
Mix some rapid set flexible adhesive to a slump free consistency and smooth over the cables with a grout float.
Make a plywood square 50mm bigger all round than the waste and use that as a shutter to stop you getting adhesive anywhere near the gulley and screws. When the adhesive is hard, eg after an hour or so, if its rapid, use an off cut of wood as a scraper to remove any high points.
