Hi all , I have an area that will be a patio that requires the levels raising , my question is, is it ok to use the waste off cuts from the light weight internal wall locks like a thermalite block ? Will these off cuts degrade in time and crumble to nothing ? I have approx 8m x 3 m to built up by 300mm . I will also use my old roof tiles and any of the concrete block off cuts etc then crushed concrete over the top. I will probably only be able to use a walker plate to compact the area. Any ideas any one? Thanks Jeff
