June 20, 20242 yr Good afternoon all I'm making a wet room and thinking of doing all the walls and ceiling in hygiene cladding. My thinking is that it will be easy to maintain whilst being waterproof. At the same time, I'm thinking, if I just put it straight onto the stud work, it will save me the cost buying and installing plasterboard or OSB behind. There will be sound insulation between the studs behind and then plasterboard or bricks on the other side (depending on which wall). I will appreciate any thoughts on the above including any recommendations for which cladding to use. I don't want to overspend but don't want something that will fall apart if someone coughs at it.
June 20, 20242 yr Hi @Pemu It would be worth looking at installation instructions for these type of boards to decide if you can use them without backing..... Good luck Marvin
