Lintels, comparable types
Does anybody know where I can find a comparison table that shows lintels from different manufacturers?
eg. What is the ig/Birtley equivalent to a Naylor r6 or a Catnic cg90?
Although there's significant overlap between manufacturers' products, each manufacture could have slightly different criteria for the use of each lintel. So really you should be checking what you need for each particular use case.
