Positioning new CU, best CU, connecting CU to meter
16 hours ago, ProDave said:
Moving the CU to the other side of the wall and poking the cables through may well result in the cable drops no longer being in a safe zone.  Easily rectified by say putting a socket on the wall in line with the line of the cable drops.
 They're all running within 150mm of corner of room so thankfully not a problem, but a good shout on sticking a socket as a way around it, hadn't thought of that!
