Hi,
I recently renovated my house and had an old two-bay garage demolished. I'm building a new three-bay garage in a different position to the original but I'm considering extending it so that it covers an old, disused swimming pool with the aim of potentially renovating the pool and adding a gym, shower, sauna, etc.
I note that the following guidance on VAT implies that a garage can be zero-rated for VAT:
https://www.gov.uk/guidance/buildings-and-construction-vat-notice-708#para3-2-1
However, in the same document, it mentions that enclosed pools can't be zero rated - it does seem odd that two examples of incidental use, i.e. not ancillary, can have different VAT rules.
It might sound complicated but I wondered if I can have the garage built, extend it as an enclosed pool/gym and claim (say) one-third (for the garage bit) of the VAT back - does that sound reasonable?
Does it even qualify for zero rating? It isn't residential.
If it does  you could put a suspended floor over the pool. Beam and block.
That would be my solution anway regardless of being able to dismantle it if you changed your mind later.
My mistake I think - having re-read the guidance:
The sixth type of qualifying building is constructed when all of the following apply:
1. a garage is built, or a building is converted into a garage
2. the building is constructed or converted at the same time as, and intended to be occupied with a building ‘designed as a dwelling or number of dwellings’ ― read paragraph 14.2
I missed the "all of the following". It's definitely not being built at the same time as any buildings designed as a dwelling.
Perhaps the incoming Labour government will lower the VAT rate, or, God forbid, raise it!
