Letsbuild2
Insulation, how are you going to do it. Biggest consideration is getting suitable level of Insulation in floor and roof whil still maintaining 2.5m overall, and having a decent floor to ceiling height.
If it doesn't have high occupancy you could do a hybrid room. Have a look at oakwood garden rooms on YouTube regarding there thoughts on hybrid roofs.
With a 5m roof span you will need to consider you roof construction and maybe go 400 cars to reduce roof depth. Also need to consider the roof fall and what this will do you floor to ceiling hieght.
How are you dealing with rain water from the roof?
Thanks , all things to consider,  we digging out with digger to get insulation into floor , digger doing footings as well , all starts next week , mostly expert labour has been employed just wanted to double check on the boundary thing , 5mtrs wide by 4.8 mtrs and going 50000mm up to fence , I believe this allowed given it non combustible am I right , cheers for your input
