Hello
I had an ACOND 16Kw ashp installed before Christmas. I only got the Scheduler last month. I can't schedule the heating at a reasonable temperature (18C) to run consistently and the running costs seem extortionate. Has anyone mastered their Scheduler settings for this particular heat pump? I'd be interested to know the exact settings that I could try for the underfloor, radiators and Return Water. (btw: I am not using the hot water at the moment as I am renovating and do not yet have any hot taps. The DHW is set at 12C for this reason)
How are you trying to set it up?
What flow temps and for how long etc? Big heat pumps are really best run on weather compensation or a low set flow temperature for very long periods.
Do you have lots of zones, buffer cylinder, explain your setup?
