Carpe Diem Posted February 12, 2024 Posted February 12, 2024 Hi, We have recently completed a project that is Loxone and Delta Light throughout. Most of the circuits are Dali. We have an issue where some lamps have a residual glow, which I understand is common and easy to resolve.... except we dont seem to be able to resolve it. We have 2 main areas where this is an issue and one is really strange. 2 Issues: 1. We have 12 lights in a double height hall way, all wired the same with one driver between 2 lamps. 6 glow and 6 dont, yet they are all the same lamp, same driver, same settings. Any ideas? 2. We have 3 lamps on a single driver. With one lamp it is fine, we put 3 lamps on and it glows. These are easy to access as they are in the ground, so we put a tester on it and there is still 1.5v through the driver even when turned 0% on. Delta Light has said to include a 27k restistor. We did that and no difference. We even put 3 in series and no dimming at all. Is this an issue with the Dali module from Loxone, the driver or the lamps both from Delta Light, or something else?
