Our proposed build design is a brick clad ground floor and Cedral cladding on the first.
I intend to utilise aerobarrier  to get as good an airtightness seal as i can. This is as well as taping everything i can. The SIPs panels themselves are pretty good as a barrier.
If it turns out i think i need/want even more insulation is the blown in Thermobead solution suitable between a SIP panel & brick skin? Any reason why not.
Not sure how i will improve the Cedral clad to the first floor as i think it is open at the bottom.  Can that be correct?
