GF insulation & screed: 75mm + 45mm screed vs 95mm + 25mm liquid screed
Hi all,
We've got the following two options, please can you advise ?
Option 1
  1. Kingspan K103 at 75mm depth
  2. 45mm to 65mm of sand/cement screed with hardener
Option 2
  2. 2nd layer of floor insulation at 20mm depth
  3. 25mm to 45mm of Liquid screed
Thought process is:
  1. The K103 is already purchased and on-site, so no option to go with a different product
  2. This would be a significant improvement in performance: u value goes from 0.158 -> 0.138
  3. A liquid screed would conduct more heat into the building, rather than below the house, so would be more efficient to run
Key notes:
1) This is on Ground Floor. Construction is beam and block.
2) We have UFH.
Questions:
1) Does this make sense ?
2) Is there a disadvantage to a liquid screed ?
3) Are there any issues with laying a 20mm depth PIR on top of a 75mm depth PIR ?
