Should I install a DPM or a Moisture barrier in this circumstance:
Suspended timber ground floor above concrete oversite
22mm moisture resistant T&G chip board- stuck with Caber D4 glue
???? Either Howdens DPM or Bitumen Moisture barrier paper???
Laminate underlay
Laminate flooring
All laminate joints will be sealed - kitchen area.
Thanks for your thoughts
Marvin.
Edited by Marvin
clarification
  • Marvin changed the title to DPM or Bitumen Moisture barrier paper?
Whilst I think about it what's the difference between a DPM and Bitumen moisture barrier paper under laminate flooring?
