Simon L H Posted January 9, 2024 Posted January 9, 2024 Im looking at retrofitting u/f heating to existing cottage with no insulation under ground bearing slab. I think its going to need some insulation, even if minimal 25mm. spoke to Nu Heat who suggested it wasnt required with their Lo Pro. until I mentioned Building Regs and they suggested .. oh yes, it might need insulation in that case. looking to demonstrate ground floor is insulated enough to limit heat losses no more than 10W/m2. Any heat loss calculation guides recommended?
JohnMo Posted January 9, 2024 Posted January 9, 2024 Lots of recent threads on the same subject so have a read in the UFH section. Common theme is expensive to run, you need insulation etc. don't trust someone trying to sell you something
