nmh Posted January 3, 2024 Share Posted January 3, 2024 I think I should have used wafer head jack-point screws to connect the MF5 bars to the MF7 bars as in the video link here. https://youtu.be/hhX4n7RT8Uo?feature=shared I used Gypframe MF9 Connecting Clips and when you walk on the floor above, or open and close the door, the ceiling squeaks a lot! Anyone else had an issue with this and know of a solution. I can't easily use screws now the ceiling below is up. Can I screw them in from above? Or use some rubber insulation between the clips and the MF7? Many thanks MF9 clip 2.mov Link to comment Share on other sites More sharing options...
nod Posted January 3, 2024 Share Posted January 3, 2024 It’ was a pretty common problem when the clips where widely used Just foam up around the offending clips Link to comment Share on other sites More sharing options...
nmh Posted January 3, 2024 Author Share Posted January 3, 2024 Thanks so much for this. Excuse my ignorance but do you mean just spray a foam around the clip? What sort of foam? Many thanks 2 hours ago, nod said: It’ was a pretty common problem when the clips where widely used Just foam up around the offending clips Link to comment Share on other sites More sharing options...
nod Posted January 3, 2024 Share Posted January 3, 2024 1 hour ago, nmh said: Thanks so much for this. Excuse my ignorance but do you mean just spray a foam around the clip? What sort of foam? Many thanks Yes just spray some fire foam (Pink) Or even a blob of silicone It just cushions the clip Link to comment Share on other sites More sharing options...
