Electric boiler supllying underfloor heating manifold
Jakeb
Good Day Team,
Im a plumber gas fitter from New Zealand and have been ask to install pipe work from a boiler to underfloor heating manifold, i just want to assure ive got this correct before i proceed.
The manifold has been installed by others and ive supplied the boiler.
They have left behind the wiring centre, 2 thermostats, 1 zone valve and the actuators.
System only 13 KW electric boiler supplying a 2 zone underfloor heating manifold, if someone could confirm the valving is correct that would be appreciated.
Do i need a automatic by pass valve or is a standard gate valve in the open postistion okay?
Ive attached a rough sketch some advice would be appreciated.
Usaully the supplier would give me all this info but i cannot get that from the supplier here (not very helpful).
Cheers
UFH draft.pdf
On 09/12/2023 at 10:17, Jakeb said:
@Nickfromwales any advice mate?
Looks like it will function fine if installed as per the diagram tbh, just down to how well the boiler can modulate / cope with low heat loads (when the rooms get up to temp).
5 wire zone valve I assume, so the boiler can't fire until the ZV is fully open?
