LVT over a cemfloor screed
Im planning on DIYing an LVT install, about 25sqm. It will be on a 6 month old cemfloor screed with wet UF.
Am I right in thinking that after a good clean I can use use a smoothing compound direct without any other prep work.
Any advice would be greatly appreciated.
You will need to prime the floor first
We normally use tile master primer
But most of the self leveling compounds have there own primer
OK thanks, how long before would you normally prime before smoothing?
Liquid prime Give it a couple of hours then pour your self leveling Go round it the following morning with a tubing stone Sweep and your good to go
Thanks, hoping to tackle it this week.
