Mattg4321 Posted November 13, 2023 Posted November 13, 2023 19 hours ago, Adsibob said: Will the snubber/capacitor that was linked to earlier in the thread work, regardless of the voltage requirements of my LED? Yes. You fit it on the 230v wiring between the switched live/line of the light fitting and the neutral. Depending on how it is wired it can be done at the switch, the light or at a joint in some other position. The switch would be the first place to check to see if the neutral is there.
