So I've got my quote from SPEN to move my cut-out.  They want me to provide ducting meeting ENATS 12-24 standard, 50mm ID, in red.  Google is unable to find anything meeting this spec...
There is class 3 twin-wall ducting OD63mm/ID50mm to EN 61386 but its not ENATS certified.  And its black.  Red seems to be more for HV cables.
Any ideas?
What I found was regardless of what spec you get sent (and I had a similar problem to you) the guys that come and do the work don’t actually care about the ducting you’ve used as long as it’s electrical ducting and suitable for the job. Even then the guys told me as long as its black twinwall.
