Brendan Posted October 4, 2023 Share Posted October 4, 2023 (edited) Unfortunately my arse met the unnecessarily long copper pipe protruding from the wall for the shower hot feed and bent it (probably about a 20 degree bend). So the pipe is now kinked. The bathroom is already tiled. If I'm lucky I might be able to pull the pipe out far enough to cut behind the kink and then solder on a new section - but the pipe is only meant to protrude by 21mm from the finished wall surface and needs to be narrow enough to go through the close-fitting valve that has a compression fitting to attach. Is there any chance I can un-kink this pipe, or is it likely to be removing the shower screen, taking out a tile and soldering a new bit of pipe on further back into the wall cavity? Edited October 4, 2023 by Brendan Link to comment Share on other sites More sharing options...
Mr Punter Posted October 4, 2023 Share Posted October 4, 2023 3 minutes ago, Brendan said: Unfortunately my arse met the unnecessarily long copper pipe protruding from the wall for the shower hot feed and bent it (probably about a 20 degree bend). Is this confessions of a Tory Minister? 1 Link to comment Share on other sites More sharing options...
Brendan Posted October 4, 2023 Author Share Posted October 4, 2023 My arse cheek, not my rectum. 1 Link to comment Share on other sites More sharing options...
Brendan Posted October 5, 2023 Author Share Posted October 5, 2023 (edited) Anyway, I think I might have got round the problem by swapping the showers between the en-suite and the main bathroom. The fitting for the other shower is not as tight around the pipe and I think that the end where the compression olive will sit is round so should seal properly. We shall see... (For info the very tight fitting was a Bristan shower fitting, the looser one from Mira). Edited October 5, 2023 by Brendan 1 Link to comment Share on other sites More sharing options...
