Hello, I have an EV charger going in. Image of consumer unit attached.
Would i just need a 32a MCB in the very left hand spare way on the unit?
Charger is a BG Sync with built in RCD - I think. I am just concerned about it being with the RCD in the panel. Also, possible surge protection not present. The guides i have watched seem to install a separate box.
Yes this will be completed by a qualified electrician but i am just checking his advice as it seems a bit odd to me. If the single MCB addition will work, that will be great.
Thanks very much.
It’s probably easier to install a new DB and join the tails together that way your installer doesn’t have to touch the original db and comment on its existing condition in a certificate
manufacturer will specify type of RCD  so that may not necessarily fit the existing space.
