1930s semi refurb
adrianpettitt
Hi,
My first post here. I'm looking forward to getting some top advice.
I am renovating our 1930s semi, making the existing ground floor kitchen, dining room and lounge, into an open plan space. I have already got stuck in and removed a wall and installed a wind post, specified by the structural engineer. Building control inspected that on Friday - all ok!
The kitchen floor is concrete, whilst the rest of the ground floor is wooden. Having taken up the quarry tiles I have found the subbase is very poor, very uneven and has no insulation, as you'd expect. So I am going to break is all out. BC have stated that I need;
150mm Hard core
50mm Sand
DPM
100mm Celotex PIR
100mm Concrete slab
65mm Screen
There will also be a Celotex insulation upstand around the external walls. I am also internally insulating the external walls as they have no cavity. So, to my first question: How thick should the PIR upstand be? As thick as the PIR on the walls?
Second bit of advice I'd like is on getting the new floor level! I've never done this before, so is a little daunting on how I mark the levels work off.
Thirdly, the Hardcore base has to be compacted, so which type of whacker plate do I hire? And does the blinding sand layer have to be compacted with one too? Is it the type used for doing patios or the type you see used at road works?
Enough questions for now.
Thanks in advance.
Adrian
Edited by adrianpettitt
