JohnBishop Posted August 9, 2023 Posted August 9, 2023 Hi All, I hope you are doing well. I want to install 2 PoE cameras front and back of the house. I have two small PVC windows and I want to screw the cameras into the plastic thing under the roof. How should I drill a hole to run the Ethernet? Through the window frame or at an angle through the wall on both sides? Please advise. Best regards
JohnBishop Posted August 11, 2023 Author Posted August 11, 2023 Should I drill through the window frame or try to go around the frame through the wall?
JohnBishop Posted October 13, 2023 Author Posted October 13, 2023 (edited) I actually came up with a flat CAT6 cable that still carries PoE. I can then easily run it through window without a risk of cutting the cable when closing opening the window. I think it would be better to install the camera a little lower than just above the window 2nd floor / below the roof. I have to come up with a mount so I can then attach it to the window sill. Do you think I should get some stronger piece of PVC and rather than screw it into the sill just glue it properly? Mounting it under the window also eliminates hanging cables I would have to take care of in some way. These Reolink cameras have a single cable that splits to 3 cables which is an overkill, I don't need these other sockets but I cannot get rid of them. I cannot attach the camera anywhere else because there is insulation all around. Edited October 13, 2023 by JohnBishop
