WWilts Posted July 25, 2023 Share Posted July 25, 2023 Installing SIPS panels (floor, walls, roof) for 3mx 2.5m garden room. Advice is to allow the SIPS floor to be ventilated underneath. Concrete slab in place already. Height limit overall 2500mm above ground level (which can be altered within reason). Wall panels 2400mm. Q. What is the minimum gap below the floor SIP for ventilation purposes? Would pieces of cement board under the ground frame/sole plates suffice to raise the SIP floor slightly? Is cement board sufficiently waterproof for this use? Detail would be (ground up) Concrete slab DPM Cement board Frame & SIP floor Link to comment Share on other sites More sharing options...
