Is this enough depth of 804 stone for this cottage floor?
-50mm small/medium stone
-30mm compacted 804 stone
-DPM
-100mm insulation
-DPM
-UFH in 70mm screed
I was expecting way more depth of 804 stone but the builders have put in just approx 30mm (once compacted). How much depth is needed?
Edited by Philxyz
Forgot UFH
Depends, what's under the stone? If it's well compacted rubble, then the stone is just there to provide an even surface for the next layer. But normally 100mm of stone, then 25-50mm blinding is normal.
Btw, 100mm insualtion isn't really enough for UFH, but I think you're past the point of digging down further?
