Apprentice Posted June 28, 2023 Share Posted June 28, 2023 Hi all, When I mix up concrete, I use a bag of gravel and cement but when I trowel it, in an attempt to get a nice smooth finish, I never achieve it. Should I be putting sand in the mix? Or is my troweling technique need work? Link to comment Share on other sites More sharing options...
JohnMo Posted June 28, 2023 Share Posted June 28, 2023 You need sand to make concrete or make it with ballast, which is mix of gravel down to small fines. Various grades of concrete are mixed with various quantities of sand, cement and gravel. Varying mixes get different properties depending on what you are doing with it. 1 Link to comment Share on other sites More sharing options...
Apprentice Posted July 6, 2023 Author Share Posted July 6, 2023 On 28/06/2023 at 20:27, JohnMo said: You need sand to make concrete or make it with ballast, which is mix of gravel down to small fines. Various grades of concrete are mixed with various quantities of sand, cement and gravel. Varying mixes get different properties depending on what you are doing with it. Thanks John. This is what I would use https://www.mdoshea.ie/25kg-bagged-gravel mixed with cement. But I find that when I trowel it, it never gets a smooth finish if that makes sense? Should I put sand through it as well? If so, what would the mix be? Link to comment Share on other sites More sharing options...
