Hi all
My next stage of my project is my first floor wet underfloor heating. I am using fit from below aluminium spreader plates.
I am planning the mount the thermostats for the bathrooms on the outside wall of the bathrooms. What probes can I buy that link (neostat v2) to my thermostats to monitor the temperature. The bathrooms will be completely tiled so where would I mount the probe?
Can UFH pipes touch each other?
 I will need to take some pipes through block walls, can I just do a large hole for them all to go through? Do I need to seal it after?
Is there a specific cable needed for my thermostats back to the wiring centre? Will 3 core and earth be ok? Live, neutral and Switch live?
sorry for all the questions but I just want to be clear before I start.
Many Thanks
